cannesdo's avatar
cannesdo
New carpet...Does adding a pad create problems?
I really need new carpet. I have a 2001 Alpenlite fifth-wheel. I would really like to get a pad put under it this time. I'm not a big fan of having RV places do the work. I've done a lot of work myself over the years and am thinking of getting a remnant and hiring someone to do the work directly...might check on Craigs/Angie's list or something. There's a place in San Diego where I can get the stitching for the slide edges done.
Anyone know if it creates any problems if you lift the carpet up with a pad underneath it? It seems like the slides lift up enough when they close in but am wondering if anyone every ran into issues when they added a pad?
  • They sell a moisture barrier padding that has a film of plastic on top.
    I would use a 7/16 8 lb paddig.If you look up in the phone book and find a carpet flooring supply store .They would sell whole sale.And they most likely can recommend a good installer.
    I replaced my carpet with no promblems.Just don't go buy some really thick carpet.
  • My first thought was:
    1) The slide - make sure it will clear!
    2) Second thought was the moisture that may get trapped into the pad - from coming in with wet feet or leaving the door open with dew or rain. I met someone this past weekend who actually had a linoleum floor laid and then the carpet on top to act as a barrier to the wood frame/joists and possibly prevent wood rot!
    3) Will your doors clear the additional height?
    Just a thought!
Having RV issues? Connect with others who have been in your shoes.24,294 PostsLatest Activity: Aug 02, 2025
