Mex- "It takes an intense amount of ignorance to harm an AGM battery. And the first correction is
14.4 volts static will not, cannot, won't and does not cause gassing"
I was just sayin, that mine heat up with rising amps after amps bottom out when they are full and I leave them on at 14.4. (as confirmed by LY) That can't be good for them, even though they are not (yet?)gassing.
Meanwhile, if you do that with Wets, they do gas but not heat up like that, so you are ok as long as you get there before the plates are exposed. Just add water.
To me, that means you have to be more careful with the AGMs
