egarant's avatar
egarant
Explorer III
Aug 12, 2021
New Coleman Soft Start Option vs Microair
I see Coleman (Airexcel) is offering a 13,500 btu Mach 10 NDQ quiet air conditioner with a "soft start" option.
Does anyone know what they are using and does it work as well as the Micriair that I installed in my Coleman.
I am ready to order a new RV and wondering if I should spec. the soft start option or install a Microair after the fact.
Thanks!!
  • Yes, your Microair is a better option. BUT, a Hard start kit costs(RVP brand) $35. The Microair costs $300. So, if utilizing just 1 AC unit, I would rather spend $35. Now, If I was utilizing 2 AC units on 30 amp shore Power, I would use the Microair, but it requires 2 at $300 each. Doug
  • dougrainer wrote:
    Coleman offers 2 versions of all their Roof AC units.
    1. Usually OEM only has the soft start included. The OEM requests this model because they usually are a 30 amp RV or a smaller than 4.0 k genset
    2. The standard 95% offered models without the soft start. The problem you run into, especially with supplies limited by Covid, you have to order the soft start as almost all Retailers just stock the standard without the soft start option. To determine if a RVP model has a hard start kit. Doug
    2ND NUMBER AFTER THE LETTER IN MODEL NUMBER TELLS THE TALE
    IF 5 O6 THEN NO HARD START KIT
    IF 7 -8- OR 9 HAS HARD START KIT
    Am I to assume as I am already that an aftermarket Micro-Air is better than the Coleman "soft start"?
  • Coleman offers 2 versions of all their Roof AC units.
Having RV issues? Connect with others who have been in your shoes.24,329 PostsLatest Activity: Oct 28, 2025
