RoyB, thanks for the critique. Hmmmmm------so far only 13.6 volts. My batteries read 13.2 volts when I turn the conv. off. I had to do some rewiring but not much. I had one ground wire (I wasn't sure it was ground) I couldn't figure out so I left it unattached until I turned everything on. It read 12V to gnd. so I noticed my propane detector wasn't on so I grounded the wire and the detector came on.
I have the converter on a 15 amp 120V breaker so that if needed I can turn it off while running my 7100BTU A/C on my 2K Honda generator. The locked rotor amps put a strain on my Generator. :(
If my spelling is all messed up, I whacked my right index finger with a razor knife and can't type with it.
I really have to check the 3 stage charger as they proclaim to operate at something like 14.2 for a depleted battery, 13.6 for general usaqge and 13.2 float.
Thanks again for your reply.
Marvin
