time2roll
Jun 28, 2019Nomad
Do not get a WFCO upgrade. Do not get a WFCO power center.
Far and away money better spent on Progressive Dynamics either way.
Why? Because the PD actually works as designed for true three stage charging. WFCO is about the same as your 6300 with a few more amps to the battery.
PD4645 upgrade
PD4045 complete power center
If you have more than two batteries and charge with a generator consider a higher amp rating. You may need to upgrade the wire if you do.
PD4645 upgrade
