time2roll
Jun 28, 2019Nomad
Don't put in 60 amps if you have #10 wire to the battery. #6 minimum.
With a single battery 35 amps is fine. If you go large on the boondocker it will short cycle the boost mode. Then you will need the manual adjustment to keep the voltage up. BFL loves his manual adjustments and I do not recommend it unless you have special circumstances and want to fiddle with it. Best to stay small with the Boondocker.
