Boxer_Lovers
Aug 17, 2014Explorer
OPERATOR ERROR. I discovered the FAN mode on thermostat was set to Low instead of Automatic. For some reason that setting was not allowing the heat pump to activated. In addition when I turned on the furnace, both the furnace and heat pump blowers would run.
Fan mode in auto and everything works as it should.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
