Chakara wrote:
Ok - I thought those were normal readings - thank you for confirming that Harvard!
The EMS still shows E-2 and PE-2. E-2 implies the problem still exists.
I'll get in there and do some "wiggling" of my install to confirm everything is tight and consistent, but I'm really thinking I got a defective EMS here......
-Kyle
The N to G voltage of 1.3VAC would be abnormal if there is very little current in the Neutral wire. So if there is little or no Neutral current then that 1.3 VAC N to G is likely the problem.
Take a voltage reading from RV Chassis to humid Earth Soil. If it is also 1.3 VAC then you probably have an open ground.
