FootSoldier's avatar
FootSoldier
New EU2000i surges at idle
Is that normal for these generators? Mine starts easy, runs great under load, but sure seems to surge a lot at idle. It has less than 10 hrs on it now.
I did have one issue once when it would not rev up from eco-mode to pick up the load from fu-fu coffee maker. Only happened once and has worked every time since.
Maybe just a little more break-in time will help both issues?
Thanks!
  • That's a symptom of a gummed-up carb. Did the generator sit for a long time between uses? A way to confirm is to see if the idle smooths out with partial choke application.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
