I did what you said to reset the board. The unit is perfectly level.
It is not starting on propane. The igniter clicks for 30 or so seconds and then stops but I don't think it's firing up because when the igniter is on the light in that area looking at the igniter is bright but when it stops clicking there is no light in the igniter area. There is also no swoosh like the unit is lighting. Both bottles are 100% full and the stove lights and runs fine and at the right level so the pressure should be good. So in this case what do I check next? Thanks.
