Old-Biscuit wrote:
IF your OLD one was a 6 gal Atwood....same size opening
If your OLD one was a Suburban.....lots of sidewall rebuild needed
Oughta be a STICKY about this!
Atwood ===>> Atwood, or
Suburban ===>> Suburban, not too bad.
But crossing the brands can be nasty. For those watching at home, the long dimension of a Suburban is perpendicular to the coach wall and the opening is about square. But it sticks deeper into the coach than Atwood. Atwood's long dimension is parallel to the coach wall and the opening is rectangular. Doesn't stick as far into the coach as Suburban, but it needs more interior length.
So... The issue CAN be more than just the hole in the wall, but the hole in the wall can be bad enough...
