westend
Jan 24, 2018Explorer
MrWizard wrote:Yes, I see that the Powerverters have a current sense system and shut off when power is not being drawn. I will probably end up with Master battery switch for it that can remove 12V power from the inverter. Thanks for your input!
i don't have the remote pendant
never needed it
the inverter is on full time, unless i'm working on the batteries cables
it has a load sense feature, adjust it for the smallest load, you will use
(fridge light ?) and the idle current will be minimal
I would recommed you try to google the manual
Have done just that, it's available at Tripp Lite's product site: Product support
Having RV issues? Connect with others who have been in your shoes.24,402 PostsLatest Activity: Jul 30, 2026
