Click For Full-Size Image.
Arrived today, this is it , in a temporary position on the shelf behind the sofa
it is being powered by USB power-pak, used for recharging cellphones etc.
it uses 5v power for the display, that is the reason for the USB connector
so i am going to install a 12v to 5v usb supply at the fuse panel over the fridge, where i intend to mount it
right now sitting on the shelf, i can watch it from laptop table behind the co-pilot set
wiring was straight forward, i'm not using the charge relay or discharge relay control connection options, or the under voltage / over voltage alert options ( i may implement the alert options at another time )
doing the setup, programing in the amphr capacity and zeroing the hall effect current sensor, was simple fast and esy
i'm happy to see the discharge/charge amps, voltage, and current capacity state, etc..
according to my 'old' Fluke 77 digital meter,
this display is 0.01 high, and reading should be 12.70v
i can live with that
