Old-Biscuit
Jul 01, 2018Explorer III
Captain_Happy wrote:
I've got a Suburban water heater with electric element. The water heater has no switch inside the water heater, it's fed from a breaker in the 120 volt electrical panel. The switch on the inside is for the propane only.
No way to find out if the 120 volt in feeding the element is to get yourself an volt/ohm meter and check it for power. Otherwise your just guessing
All Suburban Water Heaters WITH OEM electric element have an On/Off switch in outside compartment lower left corner behind/below gas valve.
Unless it has been removed by someone....
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
