time2roll
Oct 13, 2015Nomad
BFL13 wrote:I have to agree with RJ on this one. PD will outperform Powermax in most generator use conditions and especially in the OP's situation.
Yes, the PD with Charge Wizard helps when your converter is too far from the batts by letting you keep the 14.4 going. That does not cure the PD's lame amps though.
As for lame amps... PD would be far higher from 15 to 240 minutes. Powermax might lead for the first 15 minutes only.
Even if both are right on the battery, the Powermax is dropping down at ~75% charge. PD continues well into the 90% zone.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: May 01, 2026
