shane102
Oct 13, 2015Explorer
i did not read your posts before leaving and pulling the batteries down. Batteries are brand new and fully charged
So, here is another voltage test (probably getting boring).
The batteries are now at 12.14 volts. Turned on shore power and volts at output are 14.48 and at batteries 13.38. fan kicked on at about 4 mins and ran for about 1 min then shut off and volts at output read 13.6 and read 13.3 at battery.
Things seem to be working fine, I think. Other than the voltage drop.
I will be using generator for charging most of the time. Small gen is a 1600 watt and big gen is a 3500 watt. I will be using 1600 mostly and using 3500 when I need air conditioner.
What changes do I need to do for charging with generator.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: May 01, 2026
