BurbMan
May 27, 2022Explorer III
That is a structural panel where the styrofoam and plywood is all vacuum bonded together. I would clean up the roof as you describe, then go over it with 1/8" (3mm) plywood so you have a nice clean surface, then get a roll of EDPM rubber membrane and cover the roof with that. Glue it down. Seal around vents, etc. with Dicor self-leveling lap sealant. If the rig had a rubber roof on it before there is probably trim around the edges you can reuse.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
