TurnThePage
Jan 09, 2022Explorer
CA Traveler wrote:I have only seen USB type A female ports in the RVs I can afford to look at. USB-C ports would answer my questions right up front. Aside from that, I don't care what standard they choose, if they would just share what it is. I don't see that info mentioned anywhere. I'm currently shopping Cougars, Imagines, and Outdoors RVs. But I haven't seen that info anywhere yet, not even on the motorhomes I've looked at. Yes, I could install the ones I want, but then I would need to know if their wiring is up to snuff. This is just regular info that should be available, right?
Given the variety of USB standards it seems unlikely that there can be any RV standard. If for example you are asking about a USB-C 3.0A power source you could install the USB connectors needed for your devices powered from 12V DC or 120V AC adapters as desired.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
