afidel
Jan 09, 2022Explorer II
Personally on my last trailer I just tapped a 2 way cigarette adapter off the slide cabling before the switch, biggest 12V lines in the rig and right near the biggest flat surface not taken by other uses. On my new rig I'm planning to put in a couple cigarette adapters directly off of unpopulated 12V slots in the distribution center and installing them in the tv alcove above. I'm thinking a single high amp one to run an inverter for the tv and anything else I want to run on 120V off-grid and a 2 way or 3 way for chargers.
BTW to answer you question for my rig it's probably 2.4A, I'm running a USB powered wifi router and my home automation system off it, each calls for ~1A steady state, peaks can be higher so I put a $10 USB power pack inline.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
