tsweez
May 17, 2013Explorer
Thanks! Yeah, I tried to size the inverter the best I could. My reflex was to go to 2000w but after I started sampling my anticipated usage, I kept getting around 1000w. 1500w seemed like a good fit. I'll turn on the generator if I need my Microwave. As for my old charger, where might I find this beast so I can replace it? Engine compartment or close to the generator?
Regarding 4 batteries, okay. You all have be convinced to start with the 4.
mena661 wrote:
Like donn mentioned, change your converter out for a 3 stage unit. Two, 1500w inverter is too much for just TV and sat and not enough for most microwaves (unless its a small one then maybe). Also, go for 4 6V batteries if your going to be boondocking a lot.
EDIT: just saw your requirements. You are correct, 1500W for all that at the same time.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
