tsweez
May 18, 2013Explorer
From what I tell, at least at a glance, the IOTA is indeed a preferred solution in addition to the Progressive Dynamics controllers with their Charge Wizard. There appears to also be a good amount of information regarding the upgrade of my existing solution to both the IOTA and PD products. I'm looking at that now.
Your feedback here is most appreciated.
Tim
Tim
smkettner wrote:
Go Power converter might be excellent. Just have not read how well they do in various conditions.
Only the 6345 has a separate charging circuit that is now obsolete.
IOTA is a proven solid reliable converter and will charge your batteries great. The IQ controller module changes the converter from a single stage (fixed voltage) converter to a three stage converter. With low battery it steps up voltage for a fast charge and then in two steps drops the voltage for normal use. All multistage converters work this way. I assume Go Power is similar... just have not read much on them.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
