RVhiker's avatar
RVhiker
New Skylight: Dicor, or Eternabond, or both?
I'm putting a new skylight on my trailer. I have used Eternabond over all caulking on the roof. The new skylight will be installed using butyl caulk between the lip of the skylight and the roof membrane.
Should I:
1) use Eternabond only over the screws and lip of the skylight
2) or should I first use Dicor, let the Dicor cure, and apply Eternabond over the Dicor?
  • I believe Eternabond is supposed to be applied to a CLEAN RV surface, NOT on top of Dicor! Many new coaches I've looked at only have Eternabond on the roof main joint seals. Mine has some Dicor applied to the top of the Eternabond. When properly applied, Eternabond is pretty good stuff.
  • Maybe you'll be luckier than I with sealing a skylight. No, I didn't install it, but I had a small leak that I could never patch, even with EB and caulk.
    Finally ended up painting the frame with several coats of Heng's roof seal. Leak gone.
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 16, 2025
