time2roll
May 27, 2018Nomad
14.9 would seem a bit high depending on how long it will hold that voltage. Can you adjust the absorption voltage? Generally 14.4 to 14.8 would be a better range. The correct charging voltage is even more important if you go AGM.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
