Traveler7
May 27, 2018Explorer
red31 wrote:
go throudh the different screens and set PV off to what you would like, the default is supposed to be 14.7v (temp compensated).
Use a voltmeter to confirm the actual battery voltage (and/or the controller battery terminals) compared to the display and the app
controller manual
http://www.jyinverter.com/upload/file/2016-01/20160113102409-0411-33109.pdf
OK- I checked with the multimeter and with the panel connected and charging the battery voltage read 16.8 at the posts. I disconnected the panel and the battery voltager dropped to 13.5.
The Battery Monitor is reading correctly and with the panel disconnected the Charge Controller also reads 13.5- so correct?
Is the 16.8 dangerous or is it desulfating??
Anyway, the panel is switched off now until I can hear from someone about this!
Thank you!!!!
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
