red31
May 28, 2018Explorer
panel voltage is irrelevant at this time. Are you suggesting that the bluetooth meter connected to the battery is a couple of volts off?
Below is what my ole cotroller did, PV and battery volts near identical till battery V = 14.4v (AGM). Battery voltage stayed constant 14.4v for 2 hrs then the controller droped its output to 13.? FLOAT, of course I did not cut off the time scale!
It seems you controller is not controlling the voltage properly.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
