Traveler7
May 28, 2018Explorer
red31 wrote:time2roll wrote:
Why are you even reading panel voltage? Just making this confusing.
Panel voltage is irrelevant.
I believe the OP is suggesting that at the battery the voltage jumps (rises) to 16+v.
'Even under charge', the OP should only see max 14.4 or 14.6v at the battery.
Yes. My readings are all off the battery post where the controller is attached.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
