Traveler7's avatar
Traveler7
^^^^^New Solar Install Battery Safety Question^^^^^
Good Morning- I just completed a project putting a 150 Watt Poly Panel on my Camper Van and I have an older RV Battery it is charging- my concern is with the voltages and the battery type.
The battery is a Les Schwab Deep Cycle RV- I'm sorry, but I do not know the Amp Hour rating it has a part number of 24DC-550, The battery was used and I had a trickle charger keeping it at around 12,6 Volts only.
Here is a pic of the battery
The Solar COntroller is an inexpensive 10 Amp PWM
And here is a battery monitor screenshot of the chargning output
As you can see- the controller is putting a little over 4 amps in and cycling up to aroung 14.9 volts according to its screen.
My concern is if this is overcharging the battery and should I be worried?
Sorry, I know I should have a better grasp on this stuff, but my intention was to be using a new 100 AH AGM battery- just haven;t bought it yet.....
Thank you for checking this and helping me!
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
