Ductape's avatar
Ductape
New Solar install feedback?
Well, since we got a new DP to start the new year, I have to do solar again. We travel for about six month each year and boondock as much as possible. I want enough solar to handle routine loads and keep the batteries topped off, but have no objection to running the gen for heavy load times like electric cooking or if the weather is too cold and we run a lot of heat.
Due to limited space on the roof I don't plan for a 100% solar solution. On our previous coach we had 630W on the roof, which worked quite well and we rarely needed the genset unless camped in the trees. What I have space for (while maintaining easy walking on top) is 4x100 mono panels. Mono because they are narrower at 21".
For batteries, we have 600AH of Lifeline. For heavy charging, we have the Onan and a Magnum ME2012 which will charge 100A.
Given the space constraints, I basically plan for a system adequate for temperate conditions. Too much furnace and we'll need to run the genset for maybe an hour in the AM, and I'm OK with that.
Now down to specifics what do you think of this: Renogy 400W kit for $702
Last time I did this I purchased each part individually and went for maximum performance at any price. Doesn't seem like a worthy goal this time. I'm looking for reasonable performance, and something I won't shed tears over if we trade coaches again in a few years.
So... given all that, would you buy the kit, or separate components? Different controller? Different panels?
Thanks in advance for wading through this long winded post. :)
  • Don, the coach builders always cheap out on the size of the factory wiring down from the roof, so voltage drop is a concern. I'm not interested in pulling new wiring through the coach... so probably either series or series-parallel. So likely operating at 36 or 72 volts from the panels.
    The controller does have remote temp sensing.
    Controller page
    My thinking on sourcing through HD is twofold.
    Free shipping to the nearest store.
    Easy returns if there's a problem. I'll open the box in the store and see if the panels are OK. I shudder to think about shipping panels.
  • Ductape wrote:
    the coach is prewired with 10AWG from the roof which would handle parallel
    Barely.
  • Why use an MPPT controller with 12 volt panels? Is there a temperature compensation probe on the battery bank with the "kit" controller?
  • I used three 100w with my Tracer MPPT 20 amper ok (should have had a 30 amper though) and it made no difference in amps to the battery whether series or parallel. (But I have fat wiring for both ways) I also got the same amps to the battery with the Solar 30 PWM controller when I swapped that in.
  • @ Lawrosa, I absolutely would go with residential panels if I had the space. Did exactly that on the last coach; two big panels and a Midnite controller. Worked fantastic.
    But this coach has too darn many things on the roof already. I would have to relocate factory installed roof penetrations to fit a couple of big panels, and that's not happening.
    Not really too worried about the shade either. In my experience, we're either in the sun, or in the trees. :)
  • Thanks BFL, that is a repackaged Tracer I'm pretty sure. Probably do series-parallel combo. Pretty sure the coach is prewired with 10AWG from the roof which would handle parallel OK, but less voltage drop if I do series-parallel, or it looks like the controller can handle 100v so series is possible. Figured I need to study the efficiency graphs for the panels and controller to make a decision on that.
    But I'm not really looking for ultimate performance so much as reasonable performance at a reasonable price. And we'll usually hit a commercial CG every week or two, so there's an opportunity to top charge then also.
  • Youll get a lot of conflicting advice here..
    IMO the renogy did not get good reviews when I was looking for a controller...
    And also my opinion is to use 24 volt panels right from the start..
    Like two 270 watt panels hooked up in series.. Its my opinion also get the voltage to the controller. Dont worry about the shading of panels gurus. They are on the roof of RV. shading is a mute point. Either youll have shade or you will not. There is no inbetween really.
    Now you have 540 watts and 80 volts to the controller..
    https://www.renogy.com/renogy-270-watt-24-volt-polycrystalline-solar-panel/
    Thats say $525 for two panels.
    Couple it with an epever tracer 40 amp @ $190. ( They went up in price since I bought it a few months ago.
    https://www.amazon.com/EPEVER-Controller-Display-Battery-Charging/dp/B01GMUPGZA/ref=lp_11751779011_1_1?srs=11751779011&ie=UTF8&qid=1518804803&sr=8-1&th=1
    Now you are up to $715 bucks..
    Just get proper wiring and install and your done..
  • Not familiar with that controller, unless it is a Tracer. Anyway you do need at least a 30 amper for the 4-100s (6.2 each Isc) so the 40 is good.
    Not clear about parallel vs series if you want series. That is mostly about wire runs, so are the panels to be close together, or scattered here and there?
    Price seems reasonable. You could do as well with a DIY PWM for parallel. Grape 40 amper.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 19, 2025
