mike-s
May 08, 2017Explorer II
jplante4 wrote:Is the old panel also connected to the input of new controller? What are you calling "the DC bus?" The 12V bus going through the camper should be connected directly to the battery (via a fuse or breaker, and possibly a cutoff switch), so it shouldn't be at a voltage different than the battery.
Switch to the new setup with a second panel and a controller with the old panel connected on the roof. The controller says under no load there is 16.9 v on the DC bus...The actual battery voltage is 13.4-13.8 if the coach is sitting in the sun.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
