TexasChaps
May 12, 2017Explorer
jplante4 wrote:
As promised
Controller
Panel
I still need to verify that the output of the controller is wired directly to the batteries.
ok, it's a simple PWM type, probably positive ground, but I can't seem to find a manual online for it. so I will suggest you re check the wiring. you have 4 wires, two from the panel and 2 to the battery.. please make sure the wiring polarity is correct as indicated on the controller. also make sure the panel wiring is not grounded.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
