jplante4
May 15, 2017Explorer II
CA Traveler wrote:
The CC is also not wired to the batteries in a balanced manor. I'd guess that the batteries themselves are not wired as balanced but can't see remaining 2 batteries. This effects battery life so something you might want to correct in the future.
My thoughts as well. I'll move the positive from the CC to the other set of 6v which should set up charge current across the entire bank. The inter-connect cables are the same length between 6v to 6v and between 12v banks, so I believe the batteries are balanced. They seem to be consuming the same amount of water.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
