fj12ryder
Dec 11, 2018Explorer III
TechWriter wrote:Yes, I read that, but my question was: Will it connect if there is a problem in the first place? Fer example: will it connect and allow power to the RV if there is an open neutral? Most problems are when you first try to connect. Will this surge guard connect if there are issues, or not allow power to pass through?fj12ryder wrote:
I don't really give a hoot about bluetooth connectivity and range, but how it actually works. Like will it not connect if there is power pedestal issues? Will it shut down if there is an open ground or an open neutral? Will it connect if there is a reversed neutral?
You didn't read my review very well. In that review I said . . .
while the Power WatchDog will alert you if it finds an electrical error, it can only tell you that there is a problem. It can’t disconnect your RV from the power source . . .
So you could have multiple issues, but it will go ahead and supply power to your RV and fry your electronics? But it will tell you what happened and why your stuff fried? That's not such a good system.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 03, 2026
