Old-Biscuit
Dec 04, 2018Explorer III
nineoaks2004 wrote:
The high limit thermostat button might have blown also...
Water heater wouldn't work on electric or propane if that was the case.
Atwood water heater uses the ECO (Energy Cut Off--hi temp t-stat) as part of control loop on either heat source
Luke warm water is a result of mixing Hot with Cold
*Bypass valve
*MIXING Valve hot side clogged (if it is an XT model)
*Shower only turned off with lever/button on handles
*The T-stat is opening too soon
Test water temp at T&P Relief valve after a heating cycle..... CAUTION: WATER COULD BE VERY HOT (140*F) if standard model
or (155*F) if XT model
Which Model do you have?
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 01, 2026
