tenbear wrote:
Did you check the voltage on the battery posts? You said you had 13.2v at the battery, that should charge the battery, but very slowly. If you checked the voltage between the positive battery post and a ground, maybe the negative battery connector is bad.
Can you tell us what the make and model of your converter is? From what I have read so far, I think buying a new converter would not solve your problem.
When I checked the battery, I checked it post to post. The converter is a Tod Engineering Sales, Inc. PC45A 45 amp.
