Kach's avatar
Kach
New trailer, new challenges
Hello all!! It’s been a good while since I’ve been active on here, but always seem to pick up good info from the archives when google searching.
We are back in the RV’ing game with our new Highland Ridge 26BH stick and tin trailer. As expected, the overall quality is a bit lackluster - I bought it expecting to beef things up and make mods over time.
The one thing I’ve been fighting is battery charging for boondocking with the WFCO 8735 converter. Typical 13.6v, no boost mode conundrum. Basically, this thing pretty much needs to go. I’ve looked at the “Boondocker” model replacement converters (leaves the original distribution panel in place). I’m fairly convinced this would help.
1) what amperage should I get? I’m hoping to get by with my 2 6v batteries if possible. I run a Honda 1000 generator (only for batt charging purposes) - would be willing to upgrade if it makes a substantial difference. With our last trailer, we could go almost indefinitely with 2-3 hours of gen runtime per day. Now - not so much!
2) Some supplemental solar is in our future. Is there a solar charge controller that also allows 110//generator charging input? Thought Is I could leave the converter alone and wire up a separate charging setup close to the batteries with large guage wire for better efficiency. Just a thought, if such a thing exists.
  • Bobbo's avatar
    Bobbo
    Explorer III
    1. It depends on the size and length of the wires going to the batteries. For example, 30 feet of 12g wire can't carry nearly as much amperage as 2 feet of 4g wire. You need to see what gauge wire was used and estimate its length. Then get back to us. Also, there is a breaker between the converter/charger and the battery. You need to know what size it is.
    2. The solar charge is separate from the converter charge. The solar charge controller is connected directly to the battery and doesn't even know the converter/charger is attached. There will be no conflict.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Mar 02, 2026
