2oldman
Mar 26, 2019Explorer II
jornvango wrote:If the charger actually drew 3.2a, then it would be 32! The rule is that for any given 120vac amperage, the 12vdc amperage is 10 times that. Why? Because 12v is 1/10 of 120v, and watts must be conserved.
So it appears to me that the solar is providing 2.8 Amps while the laptop is taking 10.8 A? Or is it taking 3.2 A?
Your charger's output is about 20x11 or 220 watts. Assuming about the same power goes in to it, I'll let you figure out what the amperage would be coming from the battery. This is stuff any good RV electrician should know.
To make any sense of all these voltages and amps, you must convert it all to watts first.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
