johntank
Feb 21, 2016Explorer
Sounds like the nut came off of the spring tie bolt, either way this bolt does not hold the spring to the axle or U bolt plate, it does have a stud on one side to align the axle in the right spot on the spring (on top for axle above spring or bottom axle below spring). I would go to a auto parts house with said bolt and get a new one to replace it with, For this one needs a couple of C clamps to pull the springs back together with bolt in place minus the nut, once springs are back together the nut can be replaced.
Hope this helps some.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
