Teejs's avatar
Teejs
Nikota JD3000 Jiang dong new Gen-head 'Jumper' question
Some background: I installed but did not complete the install of a new Generator head set.
On the connector block where the stator wires connect to the controls harness I noticed that there are 2 pairs of jumpers attached. The 2 pairs are both on the same middle 2 posts....piggybacked on top of the stator wire connectors.
I do not remember seeing these on the original gen-head. Should I just discard them or.....? Any help will be much appreciated.
  • Not to bash on you but that is why you either have a diagram, Most can be found online, Make a diagram or take pictures.
    If you have the make and model of your generator you should be able to either contact the manufacturer or find it online.
Having RV issues? Connect with others who have been in your shoes.24,195 PostsLatest Activity: Feb 04, 2025
