BFL13
May 15, 2014Explorer II
I missed whatever set that off :) but good points on generator charging to get the job done with least gen running time.
I am not sure what is meant by "hitting them up-front" with 14.4v. I use a charging rate of about 25-30% with chargers that go to 14.8, but the batteries just can't jump that fast in voltage--it takes time with amps going in to get battery voltage to rise.
The higher the charging rate, the sooner you get to 14.4v, but at a lower SOC. To have any constant amp stage your charging rate needs to be under about 33% or amps will just taper from the beginning if you start with batteries at 50% and a huge charging rate. (Might not be anything wrong with tapering from the start, but I like to see at least a few minutes of constant amps first--makes me feel things are going along properly. Feeling is an emotion though, not science)
As to practical equipment limits while camping, your generator can only run so many watts worth of chargers. You can get more amps by using power-factor corrected chargers instead of the more common non-corrected types.
My Honda 3000 gen can run 130amps using non-power factor corrected Vector chargers but pops its breaker at 135a I can use my PowerMax PF corrected 100a charger plus some Vectors and now I can make 150a. You have to start somewhere picking your equipment.
If you start with your battery bank of say 460AH, and you decide you will charge at 30% charging rate (138a) then you can get enough chargers to do 138a and a gen that will run the chargers. From above that would be a Honda 3000. A 2000 isn't enough. Be ok for a bank of two 6s though.
My goal is to complete a "50-90" in two hours. I can do that with 130a on 460AH. I have had 6 batteries in a bank of 720AH (approx.)and used just the 100a charger plus a 40a Vector for 140a which is a 19.4% charging rate. That runs me over the two hours, more like 2.5 hours, but my Honda 3000 is the limiting factor, which is the point Mex was making.
You need enough gen to run enough chargers to get your charging rate that will meet your time requirement. (My two hour requirement comes from local provincial parks which have gen hours from 9-11am and 6-8pm and I do the recharge in the morning)
Mex gets his requirement from gas prices to run the gen. Others want the noise to stop as soon as possible. Or all of the above.
I have an ugly graph you can search for, which gives the times to do a 50-90 for various charging rates. From that you can design your perfect set-up.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
