BurbMan
Oct 28, 2014Explorer III
Be sure to install the 2 nitrogen-filled tires on the same axle, and the 2 air-filled tires on the other axle. DO NOT put the nitrogen tires on one side and the air tires on the other side or you will cause serious handling problems that will affect drivability, especially in windy conditions.
Ideally you would have all air or all nitrogen, but if you have to mix them be sure they are on the same axle.
:B
:B
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
