Muddydogs
Oct 28, 2014Explorer
Why don't you try the two nitrogen tires and 2 air tires together and then in a few months post back up your findings. I think you will find that there is no need to top off tires and your pressures will very very little.
I just don't get the posters on this subject. You guys are the first to talk about how important tire pressures are and how often you check them but when nitrogen comes up you guys throw a fit about how its a gimmick and not needed. Well as a guy who has ran nitrogen in pickup tires for 2 years and monitored the pressures for that time I will tell ya there was no need to top of the tires as the pressure stayed within 2 pounds from 20 degrees to 100 degrees. I am planning on having my new truck tires as will as the trailer tires filled and since the price has come down to $15 per four tires there is no reason not to.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
