v10superduty
Oct 28, 2014Explorer
BurbMan wrote:
Be sure to install the 2 nitrogen-filled tires on the same axle, and the 2 air-filled tires on the other axle. DO NOT put the nitrogen tires on one side and the air tires on the other side or you will cause serious handling problems that will affect drivability, especially in windy conditions.
Ideally you would have all air or all nitrogen, but if you have to mix them be sure they are on the same axle.
:B
You do have a smiley face at end of your post but I can't figure out if serious or sarcasm here.. :h
Since you have been on forum since 2001 I have to guess you are funnin us. :W
If not, well OK !!!
No need for unneccasary panic folks. If the pressure is the same in all four, no problem.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
