_1Flyboy
Feb 01, 2023Explorer II
enblethen….. When I tested the voltage from my Honda 2200 it was showing 125 volts at the plug. When I tested power at the element and the frame I was getting 12.5 volts ( Honda was on ECO mode & not on high revs )… Did a continuity check on outside switch and values did not change either on / off. Bad outside switch?
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
