wnjj
Feb 02, 2023Explorer II
enblethen wrote:
Your Honda genset has a floating neutral. Your reading between element and frame can be missing leading. For my inverter genset, I made a plug cheater that ties the neutral and ground together. It is inserted into the duplex receptacle.
Great point.
When measuring AC voltages around the water heater, use the other pin on the element as the neutral (the one not connected to the relay/switch/limit switch).
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
