daveinSD wrote:
I just plugged ac into one of the ... plug ins. No special place for the inverter so I assumed the inverter is wired into all 3. Tried all 3 after and no joy. Also, no special fuse for inverter that i can see...all listed in volts. I called the guy who installed the extra battery in series and he said it may be a wiring issue in between the inverter and one of the plug ins. But now can't plug into anything. How would the ac affect no longer being able to have 11?
your going to have to a better job of describing what your issue is.
first link what inverter you have, and maybe some pictures of the wiring.
if the inverter is standalone, it should have nothing to do with the original wiring. check a circuit breaker both in the house and in the rv.
