daveinSD's avatar
daveinSD
No 110/plug in for pop up
I was plugged in to house power, prepping pop up for weekend. I had a portable air conditioning unit plugged in and it was working fine. Then was the time to test batteries. Yes I have an inverter, and two batteries up front. As soon as I unplugged from shore power the whole rig lost power. I waited a bit, the camper has dome lights, and power to the radio inside, so its getting power, but no ability to plug in anything. NO circuit breakers blew, no fuses lit up.
So I plugged camper back in, and same result.
Anyone have any ideas? I've pretty much given up on the AC unit, assuming its pulling to much from the camper; I don't know.
But how do I get the 110 back?
Thanks.
  • Fuse in your inverter?
    As littlebill said, you probably won't be able to run the ac off the inverter.
  • did you plug into the inverter? what size is the inverter? you will probably not be able to run the ac off the inverter if that was your plan.
Having RV issues? Connect with others who have been in your shoes.24,240 PostsLatest Activity: May 01, 2025
