pianotuna
Jun 14, 2013Nomad III
Hi harold,
Nada to do with 12 volt from the battery.
There may be a disconnect switch. Turn it on.
There may be a circuit breaker between the converter and the battery bank. Mine are automatic but some require manual resets
There may be a fuse that has failed.
harold1946 wrote:
Indications are its the transfer switch. If you know its location tap it and see if it will switch.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
