BFL13
Jun 14, 2013Explorer II
tombstn wrote:
Thanks all, I will check the problems but I had 13.6 volts when I checked it and before leaving I put my battery charger on the battery and it is full. I have a 1996 Playmor. I followed the wires from the battery and they go to a thing that looks like a solenoid/old starter relay. Could that be the problem.
Yes. As above, your converter makes 12v ok when it has 120v input.
No converter, no 12v, means the battery 12v is not reaching the 12v fuse panel. Again, as above, that means the battery disconnect switch is open, or the battery fuse or DC circuit breaker (whichever you have) is blown, or that solenoid is stuck.
MHs have the battery disconnect switch in two stages..the stitch you use only operates the solenoid switch.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
