handye9
Jun 15, 2013Explorer II
tombstn wrote:
Thanks all, I will check the problems but I had 13.6 volts when I checked it and before leaving I put my battery charger on the battery and it is full. I have a 1996 Playmor. I followed the wires from the battery and they go to a thing that looks like a solenoid/old starter relay. Could that be the problem.
Does it look like this?
Use a meter to see if power is getting through this breaker. Between the two terminals, you should see same voltage as you see on the battery. Another way to test, disconnect battery and test for continuity between the breaker terminals.
Some have a reset button, some don't. They are available at most auto parts stores.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
