mchero's avatar
mchero
No 12VDC at batwing
Noticed that the batwing antenna was getting ZIP for stations. I climbed up on top of the rig & found NO 12vdc at the batwing. I don't have the Winegard power injector. The antenna "should" be getting the 12vdc thru the video distribution box BUT no 12vdc out the back.
Wondering where I can get a simple 12VDC power injector. Ideas?
Thanks
  • Could be bad switch in video box or connection inside.
    That is if you are getting good 12 volts and ground to video switch.
  • It's usually a cable issue- have you tested the BOMB (box of many buttons) to see if it is supplying the power?
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
